I joined this morning to look at a pic, so I figured I might as well post too.
Anyhow, my dad bought an 87 Pickup with a 22R/5 speed combo. It shifted fine when I test drove it and for about a week later. The day before driving to TN though it started giving issues. With the clutch pedal jammed into the floor, sometimes it won't start. No biggie, just hit the clutch start cancel. At a stop it is very hard to get into 1-4, but eventually it gets into one of them and then they are all fine until the next time you stop. It is also very hard to downshift when moving into any lower gear. Double clutching works though.
I also have an 87 with the same drivetrain. I'm starting to see the same issues. At a stop its damn near impossible to get it into gear. Once in though, no problem. I can downshift just fine though at least all the way into second. Once I stop though, it becomes a real problem. I noticed when I am slowing down however, I can put light pressure towards first and at some point the shifter will just slide in.
I hope both of us have the same issue, and hope its a fairly easy fix. I've been trying to read and the easiest things do to seem to be replace the shifter seat, master cylinder, slave clyinder, and the line.
I see the resevior has fluid and I have not noticed a leak anywhere. Both trucks are over 175k miles.
Thanks.
Thanks.
