WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
I haven't responded much after asking you if you could acquire some rail matching your current frame.
I'm still waffling around at a good solution.
Some truck frames do flex some are actually designed to be very limited in that nature.
Question: I've tried to tell from the pictures but cannot. At the crossmembers are the frame braces continuous and stamped shapes for the most part? Or are the terminated by a cast section that attaches to the frame and to the separate crossmember?
If it's the first those generally do twist some. To what extent depends on location and suspension type.
Of its the latter you have a style frame that is designed to be very rigid and doesn't twist along its length as much. If it did the cast sections won't hold up.
I cannot remember or tell what maker of chassis you have. Freightliner vs. Kenworth vs. Mack. They all approach them differently.
Kenworth and Mack tend to build very rigid.
A Kenworth I remounted a very large body on had cast brackets. The crazy part was they where aluminum. Definitely rigid and it was not designed to flex in a twist much.
This is also true of most all modern chassis. Suspension is much better as are drive train support.
Drew's work looks awesome as usual.
