McCracken
Logan Can't See This
- Jul 9, 2005
Well, in my quest for world domination or just to have a ride that won't fall apart I have finally mounted my ORIs
So where I mounted them is the issue. Long ago I converted my 14bolt to disc brakes. I got the brackets from GLO. They've worked flawlessly for years but now the ORI is in the way. Regardless of the position on the center line of the axle tube (almost...I'm not inboarding the ORI that much). The issue is that the pin that runs through the caliper and screws into the GLO bracket can't come out because it hits the ORI. To resolve this I think I might be able to rotate the bracket 90° but that would make the caliper sit where the bleeder valve is not on top. Has anyone had issues with doing this? Could I reverse bleed the brakes and still have a good pedal?
