use caution at URE
That would depend on what type of potato canon it is (e.g. propellant style).
If it is explosive based, that's probbaly a firearm.
However if it is compression powered, then that's just, well, an air tank that happens to have a potato stuck on the end :driver: no firearm
anything used to propel an object out of a barrel is a firearm. they law views compressed air the same as hairspray and grill igniter.
otherwise BB guns and airsoft guns would be legal in city limits.
i could look up the statute but its late and im tired.
What about a potato gun? Can I bring that out there? I am going to have it mounted on my hood but that is out and the open and shouldnt be considered a concealed weapon so i will not need a permit right? :flipoff2::lol:
:shaking: Read and learn...
Department of the Treasury
Bureau of Alcohol, Tobacco, and Firearms
Washington, DC 20226
As defined in section 921(a) (3) of Title 18, United States Code (USC) the term "firearm" means --
  • (A) any weapon (including a starter gun) which will or is designed to or may readily be converted to expel a projectile by the action of an explosive;
  • (B) the frame or receiver of any such weapon;
  • (C) any firearm muffler or firearm silencer; or
  • (D) any destructive device. Such term does not include an antique firearm.
As defined in 26 USC subsection 5845(f) (2) the term destructive device includes any type of weapon by whatever name known which will, or which may readily be converted to, expel a projectile by the action of an explosive or other propellent, the barrel or barrels of which have a bore of more than one-half inch in diameter, except a shotgun or shotgun shell which the Secretary or his delegate finds is generally recognized as particularly suitable for sporting purposes; and (3) any combination of parts either designed or intended for use in converting any device into a destructive device as defined in subparagraphs (1) and (2) and from which a destructive device may be readily assembled. The term 'destructive device' shall not include any device which is neither designed nor redesigned for use as a weapon; any device, although originally designed for use as a weapon, which is redesigned for use as a signaling, pyrotechnic, line throwing, safety, or similar device; surplus ordnance sold, loaned, or given by the Secretary of the Army pursuant to the provisions of section 4684(2), 4685, or 4686 of title 10 of the USC; or any other device which the Secretary of the Treasury or his delegate finds is not likely to be used as a weapon, or is an antique or is a rifle which the owner intends to use solely for sporting purposes.
It is unlawful for anyone to make or possess a destructive device which is not registered in accordance with the provisions of the National Firearms Act.
We have previously examined that certain muzzle loading devices known as "potato guns." These potato guns are constructed from PVC plastic tubing. They use hair spray or a similar aerosol substance for a propellant, and have some type of spark ignitor. We have determined that these devices, as described, are not firearms provided that they are used solely for launching potatoes for recreational purposes. However, any such devices which are used as weapons or used to launch other forms of projectiles may be firearms and destructive devices as defined.
Firearms Technology Branch, Room 6450
650 Massachusetts Avenue NW
Don't just speculate or repeat what someone else thinks, find the facts.
<><Fish
I have seen many illegal (I assume) guns at unf. Why do you have to have a ccp when they have a shooting range??
I was kidding about the spud launcher. But thanks!
thanks fish, was that a letter from the ATF? i had never seen that last paragraph where the potato gun was specifically mentioned.
I have never seen any rangers actually on the trail, why is that I meen i know th chevy 1500aint going in there seems like they would at least have side by sides:popcorn:
