RatLabGuy
- May 18, 2005
- Churchville, MD
OK Ford guys.... what other vehicles / years have the same lug pattern as a '73 Bronco?
The 1/2 chevys would be 5x5.Up to 93 ish f150 full size bronco up to about 2010 ram 1500, all years cj. Various 1/2 ton Chevy models in the 80d and 90s
You need to be careful with 4wd hubs they need larger center holes than newer unit bearing models. Any mid 90s 5 lug f150 would be a good donor easy to find in a junkyard
FIFYThe 1/2 chevys 2wd would be 5x5.
Do you happen to know what the needed center hole size is?Up to 93 ish f150 full size bronco up to about 2010 ram 1500, all years cj.
Corrected above
