vehicle wheel pattern match - early bronco
Up to 93 ish f150 full size bronco up to about 2010 ram 1500, all years cj.
You need to be careful with 4wd hubs they need larger center holes than newer unit bearing models. Any mid 90s 5 lug f150 would be a good donor easy to find in a junkyard
Corrected above
Up to 93 ish f150 full size bronco up to about 2010 ram 1500, all years cj. Various 1/2 ton Chevy models in the 80d and 90s
The 1/2 chevys would be 5x5.
Corrected above
Do you happen to know what the needed center hole size is?
