C.Berry
Bad News
- Aug 10, 2008
- Blacksburg, Va
I understand my junks oldish and all that but this is annoying as hell!
First off it's 99 suburban 5.7/4l80e/241 it has 171k! I've had a vibration when pulling out since I've owned it but also felt a vibration under load or on hills. So I figured the obvious and replaced, u joints, cv shafts front diff half shaft bearing and seal, had it timed "properly" no one knows how to use the damn snapon 10k computers around here apparently... so the only other time I've felt this vibration is when I ended up with needle bearings in the pan on my 94burb 1500... is this Dejavu all over again?? When I cold start the engine the vibration is bad at idle in park after warming a lil bit and driving it's only noticeable when I get to the 3200rpm range if it shifts to next gear it'll calm down bc rpm drop but still noticeable if near 3k. Any possibility of crankshaft or cam out of balance? is there any type of vibration test a dealership should be able to do? I've heard of such but never seen or witnessed such machine lol!! Any help would be great it's my dd/work truck...
