TheGeneral
New Member
- Mar 22, 2005
- Wilmington
Axle seal question
Driving my 78 F250 in four wheel drive caused thed rear end to lock up and release over and over again so I pulled both front and rear dif covers to see if the previous owner had put different gears in the front and rear..turns out he had. But heres my question, I put my truck up on the lift got distracted and left it there for two days before I pulled the covers. After I pulled the rear cover and drained all the oil I put a pile of shop rags under the diff to catch any stray leaks. The next day I came in and there was a puddle of oil underneath the passenger side brake drum. It looks like a seal of some sort in the axle has gone bad all the sudden...Why would this only happen after I pulled the diff cover off?? Is it going to stop again once I put the covers back on and fill it with oil or should I go ahead and rebuild the axle while Im regearing it?
and shut up
