McCracken
Logan Can't See This
- Jul 9, 2005
I understand the whole idea behind a sticky tire putting more stress on the front end because where you once had slip you now have grip. One thing people don't seem to understand is that you have to drive differently with a sticky tire. It's not the same. I'd say you're seeing those breaks because of lack of knowledge.
As far as your thoughts on sticky competition tires... well, I'll put it to you this way. They're made for competition. The Maxxis tires are good tires and I've seen first hand what Treps and Creepies will do. A buddy of mine runs the 40" Treps and he seems happy. The Krawlers are a good tire too but have weak sidewalls. The probelm is that they're not readily available unless you have a hook up. Whereas the new Swamper line is available to anyone with the funds.
Another issue with Treps and Creepies are that they have a tighter tread pattern and don't clean as well as they should. I ran IROKs and I loved them. I could heat them up and dig in when I needed to plus I could clean them with little effort. That's one thing I see Maxxis and Kralwers have an issue with is mud. My last tire was a Pitbull Rocker. Granted it's no competition tire but the tread is softer than the IROK. I kept having issues with the tighter tread not cleaning and it's still not as tight as a Creepy. Once again IROKs and SXs don't have this issue.
At some point you have to sit down and figure out what you need for the trails you drive. I need a tire that provides clearance because of my belly on my rig and something that can handle a sloppy trail or two. Not all trails are just rocks.
Lastly, your size vs. tire compound comparison makes no sense. Stepping down to a sticky tire is fine and I can see the advantages. Who couldn't? But to make the claim that someone needs driving lessons because they wheel a tire bigger than 40" and then suggest that a 42" is the best is nothing short of contradictory. Then you said you never thought you wanted those 3" back. Well, which is it
