natemclean93
- Jun 24, 2009
- Conover
Any reccomendations on a tow vehicle. Wife wants a honda pilot anyone ever towed with that before. If this doesn't do then I would like something like a suburban.
Looks like the Pilot has a 3,500 lb tow rating. Not enough for a Jeep on a trailer, I'd keep looking.2006 wrangler, sorry wasn't thinking
Figure 4,000-5,000 lbs for the Jeep + 1,500-2,000 lbs for the trailer, you are looking at towing 5,500-7,000 lbs. If you are going to be towing often, then you might as well step up and get a full size pick up with a diesel.
That seems a little steep. A stock wrangler is like 3200 lbs. Let's say a few mods brings that to 3500. A trailer to carry that would probably be about 1500 lbs. So I would say around 5000. You need at least some kind of fullsize vehicle to tow that much comfortably.
I'm going to go against the popular thinking here and say don't get a diesel unless its only job is to tow. I hate the smell, warmups times, noisy motor, and lack of quick throttle response on my cummins. It is a PITA on the days when I try to use it as a DD.
True. My wrangler on 35's weighed 4500 lbs last year when I had it at the Cat scales. That was pretty much empty too.No, it's not. Stock Wrangler is more like 3800-4200, and a decent dual-axle trailer is going to weigh between 1500-1800lbs. Then you start talking about bigger tires, which get heavy quick. 1/4" steel armor all over the rig, fullsize axles, a tank of fuel, etc, and you'll quickly tip the 5k mark with the Jeep. Throw in all your tools, spares, and crap you take with you camping, and you're up there pretty quickly.
at best i get roughly 14mpg in town, and much better on the highway.
