can one of you guys that has built one key up a good recipe? what cam, injectors? some of the misc. stuff? I am thinking of starting to collect to do this too..
Read and learn:
Stroker
And here it is (edited to meet 12,000 character requirement...) for future reference:
4.0 engine torque curves
The torque curve of the engine in stock form was already broad and flat. The addition of some simple bolt-on performance modifications increased torque throughout the rev range, particularly at higher revs.
Maximum horsepower increased from 193hp @ 4850rpm to 235hp @ 5200rpm, and maximum torque from 239lbft @ 3500rpm to 269lbft @ 4000rpm. The torque curve is broader, with at least 242lbft (1.0lbft/ci) available from 1600rpm to 5100rpm. This translates into faster acceleration at any speed in any gear making passing manoeuvres safer. Gas mileage remained the same despite the higher HP/TQ outputs thus reflecting the engine's greater efficiency.
When 4.0 litres and 269lbft aren't enough...
There's no replacement for displacement so if you want even more torque, you need a bigger engine.
The 4.0L engine has a 3.411" stroke, 3.875" bore, 6 cylinders, and a displacement of 241.5ci (3956cc).
You can increase the displacement of your 4.0L engine by installing a stroker kit.
At the heart of the kit is the 3.895" stroke crankshaft that was used in the AMC/Jeep 258ci (4.2L) I6 engine.
On an engine with the standard 3.875" bore, the stroker crank increases displacement to 276ci (4517cc or 4.5L).
Add 30 thou or 60 thou overbore pistons and displacement is increased to 280ci (4587cc or 4.6L) and 284ci (4657cc or 4.7L) respectively.
Larger displacements will require custom parts. For a 4.8L stroker (4759cc or 290ci), 60 thou overbore pistons and a custom billet 3.98" stroke crank are required. If a custom billet 4.06" stroke crank is used, displacement is increased to 4.9L (4855cc or 296ci). The ultimate stroker would be a 5.0L version (5016cc or 306ci) with the block resleeved to accommodate 4.00" bore pistons and the aforementioned custom billet 4.06" stroke crank.
Here's some information on how you can build a stroker engine and the kits available.
Budget stroker build-ups
Robert Bryce built the world's first budget Jeep I-6 stroker engine, reusing as many stock components as possible in his assembly to keep cost to a minimum. The key to success was to keep it simple. Click on the image to the right to find out more.
Not to be outdone, I also jumped onto the stroker bandwagon and built the world's first "square" Jeep I-6 stroker engine with a bore and stroke of 3.895". It's identical to the 4.6L "poor man's" stroker shown below except that I used a Crane 753905 camshaft. I transformed a junkyard 4.0L short block plus a pile of parts into a rip-snorting torque monster with a displacement of 4563cc, hence I entitled my stroker story
"From Junker to Stroker".
My stroker engine's producing a calculated 258hp @ 4850rpm and 320lbft @ 3500rpm. At least 278lbft (1.0lbft/ci) is available from 1500 to 4850rpm. The difference in performance over the old modified 4.0 is very noticeable, particularly from 1500-4000rpm where I need it most. Performance-wise, the stroker engine has hit the bullseye!
Stroker combinations
I've outlined several stroker combinations from mild to wild below based on budget and desired horsepower levels. To get maximum benefit from the stroker engine you need a free-flow intake with an S&B or K&N cone filter, 62mm bored HO throttle body, header, high-flow cat, performance muffler and 2.5" exhaust piping.
4.6L Low-buck, low CR "rockcrawler"
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
Custom forged +0.030" bore pistons, compression height 1.380", dish volume 32cc
8.8:1 CR
CompCams 68-115-4 192/200 degree camshaft
DIY ported HO 1.91"/1.50" 57cc cylinder head
Mopar/Victor 0.043" head gasket
0.043" quench height
Ford 24lb/hr injectors for '87-'95 engines, Bosch 0280155703 injectors for '96-'04 engines, '98 Chevy LS1 25.2lb/hr injectors for '05-'06 engines
242hp @ 4600rpm, 317lbft @ 3000rpm
4.6L Modified "poor man's" stroker
Custom forged +0.020" bore pistons, compression height 1.380", dish volume 26cc
9.25:1 CR
Stock 4.0 camshaft
249hp @ 4900rpm, 303lbft @ 3500rpm ('87-'95 camshaft)
245hp @ 4700rpm, 315lbft @ 3000rpm ('96-'04 camshaft)
Original "poor man's" stroker
Same as above but with Jeep 4.2L 5.875" rods and Sealed Power 677CP +0.020" bore pistons. Unfortunately the high 0.088" quench height makes this combination more sensitive to detonation if the fuel quality is poor. This deficiency was rectified with the use of longer 4.0L connecting rods and custom forged pistons. This modified version is a great stroker build for a mild supercharger/turbo application with up to 6psi of boost. The 4.0L connecting rod/forged piston combination offers less reciprocating mass than the 4.2L rod/677P piston combination, thereby giving this engine a potentially higher rpm capability than the original "poor man's" stroker. The tight quench also allows this engine to run on 87 octane fuel in naturally-aspirated form.
4.6L low-buck stroker
Custom forged +0.030" bore pistons, compression height 1.380", dish volume 18cc
9.6:1 CR
CompCams 68-231-4 206/214 degree camshaft
Russ Pottenger ported HO 2.00"/1.55" 62cc cylinder head
Ford 24lb/hr injectors with adjustable FPR or MAP adjuster for '87-'95 engines, Ford 24lb/hr injectors for '96-'04 engines, '99-'00 Chevy LS1 26.2lb/hr injectors for '05-'06 engines
268hp @ 4900rpm, 326lbft @ 3500rpm
NEW: Propane Conversion Special
Same as above except:
Custom forged +0.030" bore pistons, compression height 1.380", 5cc valve reliefs
11.0:1 CR
267hp @ 4900rpm, 323lbft @ 3500rpm
If you all thought that the old AMC 232 I6 crankshafts were only destined for scrapheap oblivion, think again. There are plenty of them around and with a 3.500" stroke, you can use them to convert a stock 4.0L engine into a 4.2L mini-stroker. While it doesn't have the displacement of an AMC 258 crank-based stroker, the 258 cranks are becoming increasingly scarce and expensive so a mini-stroker offers a low cost alternative to more HP/TQ:
4.2L Milder mini-stroker
AMC 232 3.500" stroke crank
Silvolite UEM-2229 +0.060" bore pistons
Increase piston dish volume to 24cc
8.8:1 CR
0.040" quench height
241hp @ 5000rpm, 293lbft @ 3500rpm
4.2L Wilder mini-stroker
9.6:1 CR
CompCams 68-235-4 210/218 degree camshaft
268hp @ 5300rpm, 303lbft @ 3900rpm
4.7L medium-buck stroker
Custom forged +0.060" bore pistons, compression height 1.380", dish volume 15cc
10.2:1 CR
Russ Pottenger ported Edelbrock 60cc aluminum cylinder head
Flometrics F&B 68mm billet TB
Accel 30lb/hr injectors for '87-'95 engines, Bosch 0280155784 injectors for '96-'04 engines, '01-'02 Chevy LS1/LS6 28.6lb/hr injectors for '05-'06 engines
290hp @ 5100rpm, 340lbft @ 3700rpm
4.8L high-buck stroker
Custom billet 3.98" stroke crank
Keith-Black UEM-IC944-060 pistons
10.0:1 CR
505 Performance 267/282-14HRK hydraulic roller camshaft
Felpro 0.051" head gasket
0.036" quench height
Dual 2.25" exhaust system
Custom PCM programming
330hp @ 5400rpm, 366lbft @ 4000rpm
4.9L high-buck stroker
Custom billet 4.06" stroke crank
Eagle forged 6.15" rods
Custom forged +0.060" bore pistons, compression height 1.275", dish volume 12cc
11.0:1 CR
505 Performance 273/273-14HR hydraulic roller camshaft
340hp @ 5300rpm, 384lbft @ 4000rpm
5.0L very high-buck stroker
Block resleeved to 4.00" bore diameter
Custom forged 4.00" bore pistons, compression height 1.275", dish volume 11cc
11.5:1 CR
505 Performance 281/281-14HR hydraulic roller camshaft
360hp @ 5500rpm, 391lbft @ 4100rpm
