wheel size cross-reference w/ classic bronco
RatLabGuy
Churchville, MD
OK here's the situation.
I need to acquire a set of roller wheels for my '73 Bronco just to be able to move it while it gets ready for rebuild. Current tires are completely dry rotted and don't hold air.
Stock axles.
What other years & models / vehicles use the same 5x5.5 pattern and center bore hole, so I know what some might come off of while digging around?
Plan B:
I do have a set of old 90s Toyota wheels/tires sitting around (rollers for my other toys).
Is it even possible to find cheap-ass adapters to go from 5x5.5 to 6x5.5?
Dodge half ton 4wd trucks from 80 to 93, then 2wd from 85 to 93. I know the 4wd center bore is bigger than the Ford, not 100% sure about 2wd but like 95% sure. After 93 the bolt pattern is the same but the hub bore and backspacing change. I know some CJ's are 5x5.5, as are some Suzuki's, but not sure about hub bore.
Duane
cool thanks
I certainly don't care if the bore is bigger. Smaller is obviously a problem,
What other Ford trucks? F150?
Yeah we found out the hard way that the Ford bore was smaller when a guy in our group had a flat and his spare wouldn't fit :dumbass:
Duane
What these two knuckle heads say …
If you were in sc ive got a set or three of steelies unsure of ties
