Blaze
The Jeeper Reaper
- Aug 9, 2005
- Wake Forest, NC
Totally incorrect. It only fills the air gaps when you use waterproof heat shrink. Idiot.
They were only 6,575 Marlboro points got the same ones in my living room!
Science of metals, duh. 60 amp parallel fuse. If they were in series, it would be a 120 amp fuse.
The 60 is blown, but fits the slot. Homie has the 2 30s in parallel bypassing the 60.Science of metals, duh. 60 amp parallel fuse. If they were in series, it would be a 120 amp fuse.
You don't understand what I do around here or some shit.The 60 is blown, but fits the slot. Homie has the 2 30s in parallel bypassing the 60.
Made from Trampoline tube^^^
Is that one of those fancy quick disconnect cages?![]()
Fra-gee-lay. I thinks it’s French…..
I zoomed in the make sure.The HF Daytona jack is what makes the picture!
Or the axe just pushes into the groundWhat happens when the Axe slips out and busts him in the nuts is my question. Or when the jack has enough pressure it comes flying out at him, cause well ....Physics and "Wheels" are not going to stay in the notch.
"Field coordination by OTHERS"
