marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
I've read up about people using factory mounts like these with the u bolts to hold them in place and then you mount the XJ spring on top of it....thoughts
I guess it's already there so saves some Fab work, and allows the spring to coil down into recessed hole rather than making flat mount...it was just a thoughtWhat would be the reason behind doing that?
Ok all right I'm stupid or lost or something somebody tell me what the heck's going on this is the other what's supposed to be spare long shaft
So I'm right that I have a full D60 and a parts 50axle....AWWWWWW SNAP thank you for confirming that.The middle shaft is for a Dana 50.
The SD front originally used this with square-ish u bolts
That's funny right there....You could always use plywood on both sides with a lot of glue and nails...
I have those top pieces too but wasn't going to use those just the other plates...maybe unless bad idea
No I'm going 4link front so would only be coil buckets...so bad idea sounds likeyour staying on leaf's I'd just use the stock plates.
Ok I wasn't sure but seen it other places. Thank youTerrible fucking idea
Where? Got a link?Ok I wasn't sure but seen it other places. Thank you
Don't know, I'll get it tomorrow. Pretty sure I've figured out it's a 60... Look at the pictures what else can it be. 2 matching axles fit into one housing the other smaller long one fits in the other. I'll find out tomorrow cause I don't think pinion yokes interchange and the SD60 one is brokeWhat size is the pinion nut?
Before you get a stiffy over an axle shaft or anything
Can you confirm or not if the D50 pinion yokes will fit the 60. Figured you might know right off the bat, thank youDidn't realize you took those out of a complete axle.
If they're 35 spline, which they appear to be, they came out of a 60.
No they won't.Can you confirm or not if the D50 pinion yokes will fit the 60. Figured you might know right off the bat, thank you
Thank youNo they won't.
Dana 50 has 1 1/8" pinion nut. 60 has 1 5/16" nut
Thanks, I've been eyeing those...worthy enough though
