Will yota axles handle this?
BrianGreen
SSG Brian Green
Kings Mountain
If I run a single stock case with 4.10 gears and 50" tires, will stock yota axles handle this power?
o_O
You reckon they'd change the oil in that thing at Walmart quick lube?
May want to use a later model front axle, or truss an early model.
IFS with drop bracket lift and a welded 4cyl rear end and some 6 inch blocks for added load capacity is the only way it will ever hold. Anything else will just shatter and cry.
Does it have custom rear tail light guards or anything booger welded to the sheet metal?
I got your clutch and flywheel right here......
