BrianGreen SSG Brian Green Joined Apr 5, 2008 Location Kings Mountain Mar 26, 2014 #1 If I run a single stock case with 4.10 gears and 50" tires, will stock yota axles handle this power?
hurt4x4 Well-Known Member Joined Sep 12, 2012 Location Greensboro Mar 26, 2014 #2 Wait for it........
77GreenMachine Phillip Talton Joined Mar 30, 2010 Location Mayodan, NC. Mar 26, 2014 #3 You reckon they'd change the oil in that thing at Walmart quick lube?
strange1 Well-Known Member Joined Mar 31, 2005 Location Elkin Mar 26, 2014 #4 May want to use a later model front axle, or truss an early model.
Chris_Keziah Joe Dirt @ Rev Limit Fab Joined Dec 1, 2010 Location Winston-Salem Mar 26, 2014 #5 IFS with drop bracket lift and a welded 4cyl rear end and some 6 inch blocks for added load capacity is the only way it will ever hold. Anything else will just shatter and cry.
Ron Dum Spiro Spero Moderator Joined Apr 16, 2005 Location Sharon, SC Mar 26, 2014 #6 Yes but you gonna need a doubler
hurt4x4 Well-Known Member Joined Sep 12, 2012 Location Greensboro Mar 26, 2014 #7 Ron said: Yes but you gonna need a doubler Click to expand... There it is
BigClay Knower of useless ZJ things Joined Sep 24, 2008 Location Winston-Salem Mar 26, 2014 #9 Does it have custom rear tail light guards or anything booger welded to the sheet metal?
mommucked Endeavoring to persevere Joined Sep 26, 2011 Location Rural Apex n.c. Mar 26, 2014 #10 Don't forget the long, narrow 12" drop front spring brackets or the oilpan will drag on mall speed bumps.
Blkvoodoo professionally useless Moderator Joined Mar 16, 2005 Location Archer Lodge Mar 26, 2014 #11 I got your clutch and flywheel right here......
BrianGreen SSG Brian Green Joined Apr 5, 2008 Location Kings Mountain Mar 27, 2014 #12 Blkvoodoo said: I got your clutch and flywheel right here...... View attachment 150646 View attachment 150647 Click to expand... Sweet! Ill let you know when I get the frame ready to drop this big boy in. How much would shipping be?
StretchASU Playing country music til Troy's ears bleed. Joined Oct 17, 2006 Location Claudville, VA Mar 27, 2014 #13 Don't try and sell it. You're not popular.
drkelly Dipstick who put two vehicles on jack stands Joined Mar 21, 2005 Location Oak Ridge/Stokesdale, NC Mar 27, 2014 #14 As long as you've got Longfields.
