hscrugby
- Mar 22, 2005
- Raleigh, NC
OK, helping a buddy replace his flywheel.
He just bought the #@*(#)($@)($@ Jeep a few months ago.
So it's been eating starters, so I pull the starter, (after seeing if anyone could think of anything besides the flywheel, wishful thinking you know?)
and see the flywheel is toast.
we agree to replace it, but it has some other issues to fix first. Bad tie rod ends, valve cover seal, some other crap. We fix all that, and I'm noticing some weird stuff, like zip ties zip tied to more zip ties to route the coolant lines for the heater to the firewall. But whatever, nothing to bad.
We get underneath to drop the transmission. That's where the weirdness starts.
First the Transmission "mount" is a piece of 1x1 box steel with some holes in it. It ain't gonna wear out I guess?
Get past that and figure out why the damn shifter is such a PITA. He ground out, (Or something, looks like he got freaky with a dremel) the grooves for the shifter, so it spins about 30-45 degrees as you try and shift. It ensures you bash the @#$# out of your fingers on your dashboard or center console.
So, we get past those, and realize we need to drop the exhaust to get the transmission off. (figured that was the case, but hoped to be lazy) I look at the exhaust, and something is weird. Instead of the O2 sensor in it's hole, there is a BIG FAWKING BOLT. bigger than the o2 sensor jammed in there. AND tacked in place with a big booger of a weld.
WTF?
So I say whatever, it's registered in Central Va, you're fine with no emissions?
We go to take the flange gasket from the header off, you know, two bolts, with two nuts on them?
Well, usually, he broke one of the heads off, so he just booger welded all over the top where the bolt head SHOULD be.
(Not to mention the usual annoying/weird jeep stuff that I planned on)
I know these aren't to horrid, but what's the worst you guys have seen? Not really like the mexican guy welding the gas tank under the 2x4 unsafe, but just made you say WTF was that asshat thinking?
Cheers
(oh and if anyone is wondering, no I still haven't fixed his damn flywheel)
WTF?
Cheers
