Front axle would be simple swap.Do yall think it would be worth it to put a set of them under a XJ? I will be running 33 LTB's , and later down the road 35's. The XJ will be a weekin toy for mild trails.
8.8 from explorer is the same 5x4.5 your front axle is.I was thinking about doing the 8.8, but then I would need to get spacers for the rear to match the bolt pattern and to make up for the wms of the front axle. And im not a big fan of spacers..
I thought for the rear all i would have to do is remove the coil mounts and weld on spring perches?
I was talking about running the 8.8 with the TJ front axle, that is were i would have to run spacers.
