Ya rustys kit came with track bar, and I got it alined, and I set all the lengths and angles sugestedd by rustys
This, I was assuming the alignment shop would have checked and adjusted the caster. Out of wack caster will make for a real scary ride.You might want to check what your caster is set at with an angle finder or if the alignment shop gave you a print out check that. If it is wandering a lot that may be your issue. Depending on who did the alignment it may have been more of a toe and go job.
