- Mar 24, 2005
- Stokesdale-Greensboro
any tips for getting the stock tranny cooler lines re-seal on an XJ AW4? Swapped transmissions (97 tranny in to 95 XJ), I'm not sure if we had all the correct pieces for the quick disconnects. I had one black plastic collar probably 3/16" long on the 95 cooler lines. Inside the QC's on the tranny, there was one green O-ring, a flat white plastic spacer, then another green O-ring. The black collar wouldnt fit with the 2x O-rings and white spacer, so we just used the black collar. I'm not surprised that sideis leaking, but the other side with 2x O-rings and white spacer is also leaking. Both leak only under pressure.
