mbalbritton
- Mar 22, 2005
- Orlando, FL
Just go to Lowes and get a can of the wasp and hornet killer. Go out at night and hose it down.
Worked like a charm for me.
I pour a 20 oz drink bottle half to full of gas and stick it in the hole. The bottle wont let the bees out and the fumes kill them.
Sent from my DROIDX using Tapatalk 2
They usually only have one entrance/exit hole. They do all come in at dark and they're not active after dark. I use professional pesticides to kill them but have never encountered one that close to a well. The nest will be less than 24" deep so as long as you don't pour 20 gallons in it you shouldn't contaminate the well. I wouldn't use gas though. Use a good insecticide that you mix with water. One gallon should do it. and it's better to mix it and spray rather than pour undiluted chemical in there.
Y'all be careful out there!x2...this guy knows his stuff!
They dug their way in and they dug out when you closed off their hole. The gas probably evaporated. You just pissed them off!Well...heres a little update. I was gonna go to lowes and get the stuff mentioned but I couldn't find my car keys. So, I got a 1liter water bottle and filled it about 3/4 of the way with gas. Went out there last night and stuck it in the hole. All the gas went in and I left the bottle. I came home from work today and they are still swarming around the bottle! Must be a sizable nest. I can't tell how they got out cause I can't get close enough. There are hundreds swarming.
Used some of this the other week, and it worked great. The Commercial Wasp/Hornet sprays better, but I do like the foaming nature of the yellow jacket stuff.![]()
Round 2....results to come...
I always pour about a gallon of gas down the hole at night and throw a match down near the hole if it's in a safe area. I've sat around and watched holes burn close to an hour before.
I know a gallon is over kill but I like to do it right.![]()
I did that about 3 weeks ago and it didn't work, but it was fun! I still prefer the sit in the car and spray method. Its very gratifying.Set it on fire and I guarantee it to kill every one in the nest or I'll give you your money back
There is or was a nest in there. All you see is a little bit of honeycomb. You probably got them.Ohhh...the saga continues...
I used the spray foam stuff. Today there are just a handful of them buzzing around the grass so I decide the dig up the nest... There was no nest in the hole I was spraying. I dug about a foot deep. I definately saw yellowjackets flying in and out of it. wtf.
I also sprayed one that was flyin around and looked at it to make sure they were indeed yellowjackets and yea they are. (neighbor behind me has bee hives)
