BLUEZUK
New Member
- Dec 12, 2006
- BISHOPVILLE SC
how does this suspension on the rear handle on the highway:
I think it would be funny to see a setup without limiting straps get rear ended... It could be possible for your rear tires to touch your fronts.
The 1/4 springs were stock MJ leafs cut up,shoved and bolted in a piece of box tubing. The shackles on the rear axle are stock XJ ones...cost $0, but yeah having them is quite the conversation piece.thats pretty awesome...
my only question would be "why" when you have essentially done everything you would need to run coils aside from buying the coils or coilovers of your choice.
I've been a throwing ideas around in my head for when I ever start a buggy, ever thought of a single center elliptic and 2 bars?
If you get your links set up properly it will handle as good as your tires will allow. A link type suspension only depends on the springs to hold the vehicles weight.it's all in the links. has very little to do with the leaf springs.
is the kit from spidertrax and what size tires. if so i have the same one.just havent instaled it yet.was it hard to install.how do you like it
