How to get rid of a stump?
Ya'll are missing a golden opportunity here--Dig around it and remove as much dirt as possible then fill voids with charcoal. Get it going good and hot for a few hours and then cover with seaweed soaked in beer and then lay a dressed pig on top and cover with Palm leaves (don't ask where to get the Palm leaves as I have no clue) flip the pig over after 4-6 hrs and cook for another 4-6. Alternately you could go the seaweed and Lobsters/clams/corn on the cob route ! much quicker than a pig. Then invite all your friends over and tell them to bring beer. Might not remove the stump completely but a much better time than rotten milk or Epsom salts !:beer:
Salt will do it. My mom poured a bag of driveway salt that had gotten wet into the bushes next to her garage. In 6 months the bushes were gone. The down side is nothing ever grew there again. She ended up planting fake flowers there.
If theyre fake are they technically planted?????????
Well I just went out to the stump and finally brought my tape measure, I underestimated the circumference a little, it is more like 24" not 18". So far I have drilled the holes and poured Epsom salts on it, but that is all. I will see how that does.
We removed a few with my buddy's work truck. Dug around it, cut what roots we could see, and wrapped a strap around it. The arm on that thing is damn strong for a rig that changes tires :D We also used it to pull up the fence posts we were moving. Much better than digging them up by hand!
I've dug up and had alot of stumps ground down here. My grinder guy makes it worth it to pay him vs renting some old weak POS. He has a monster grinder and it makes short work of the biggest stumps.
I was always under the impression that salt just changed the pH of the soil, thats why nothing grows afterwards.. Will salt actually make something rot faster?
I wouldn't think so since salt is a preservative.
I am thinking salt helps dry it out faster and allows decomp to start faster?
I don't know about the salt..but Lime works on a body ( I'm from Boston!- Don't ask )
Cut the stump down as close to ground level as you can. This removes excess material from the stump that someone could potentially trip over and helps to ensure that the salt will make it to the roots and not just be distributed through the trunk stump.
Drill into the side of the stump at a downward angle as close to the top of the stump as you can get. Make the hole large enough that you'll be able to pack it with salt, at least 1 inch in diameter. Drill additional holes every few inches around the stump; the larger the stump is, the more holes it should have.
Pack the holes with rock salt, getting as much of the salt into them as you can. If you are not concerned about grass or other plants that surround the stump, you can also place a line of additional rock salt on the ground close to the stump.
Cover the stump and the holes with soil, then cover the soil with mulch. Pour water over the soil and mulch to help dissolve the salt and to pack the soil in around it.
Water the stump every 2 to 3 days for several weeks, or more often during dry conditions, saturating the mulch. This water helps the salt to dissolve and be absorbed by the roots and stump while also encouraging the growth of fungi and other organisms that will decompose the stump.
Check the stump and roots periodically, adding more soil and water if needed to encourage decomposition. If you notice new growth appearing from the roots or around the stump, cut off the new growth and repeat the salting process to deplete nutrients from the wood and kill the stump.
So, I looked it up. Makes sense. You can also fertilize the crap out of it or feed some sort of birds near it (geese, chickens, ducks) to get the nitrogen to kill it. We all know how quick nitrogen will fry plants.
I agree...or pull it out with some heavy equipment.
holy crap!
There are pieces of equipment that are made to grind stumps out. It takes like an hour, maybe 2 if you do it yourself. DIY cost is like $120. Pay someone to do it is like $350 -$500. Seems like all the work involved in salting it or burning or digging it out is just way too much for the cost of grinding it out. But hey, I'm lazy I guess... :rolleyes:
holy crap!
dude, you still have to go pick it up, unload it, figure it out and start grinding. Then load it back up, take it back and pay someone $120. My method requires a chainsaw, a can of diesel/gas fuel and a propane torch. Set it and forget it. When it's done, kick dirt in the hole. I really don't see how much lazier you can get with it.
I guess it really depends on how soon you want it gone and what the city will say about a fire.
And, a grinder is a trailer. Just hook it up to the truck and go. Its not rocket science. If someone can't figure out a stump grinder, I'd hate to see them operate a chain saw
This will do it:D
*Plan your next ride @ THE FLATS 828-442-7932 *
I might could swing over to PCS Phosphate and borrow one from the mines :D
I rented a stump grinder over the Memorial Day weekend. It ended up costing me about 450 bucks for the 3 day rental. I ground 51 stumps to below grade level at my house over the weekend. Some were so large I had to move the grinder to the other side of the stump after grinding all I could from the first side.
It was a pretty large machine, it had an air cooled, turbocharged, 3 cylinder Duetz diesel engine that made 68 HP.
All the qoutes I got from the local stump grinders averaged between 125 and 150 bucks a stump.
I guess what I am getting at is that renting the stump grinder is worth every penny if you have more than two or three stumps to remove.
