mommucked
Endeavoring to persevere
- Sep 26, 2011
- Rural Apex n.c.
How much trouble is it to mount an Extracab cab on a regular cab shortbed frame, not counting the bed fabbing?
nothing worth doing is ever cheap and easy randy .on a real note I would be careful with the body lifting those things can bring on all sorts of little gremlins if not very well thought out or executed. I would definitely try and mock it up real good before making anything permanent then checking steering joints brake lines wiring making sure you have enough slack to account forframe and body flex shifter function.but I have never done a body lift or cab swap on them yota so I don't know any specific issues you will run intoThanks, I was under the impression the rear cab mounts were the only thing that needed to be changed for a 2nd gen truck swap, and what does "alot more stuff " include ?, I'm not gonna do it if it's not cheap or easy, assuming I can get a somewhat decent cab for a good price. I can rob almost everything from my reg cab, fenders, doors, dash, etc. if I can find a shell of an extracab and it will be a beater.
