Rich
Asshole at large
- Mar 17, 2005
- Central PA
Whatever jackass owned one of my rockwells before me was a total fawkin hack. I guess the welder was closer than the wrench, or the concept of getting a fine-thread nut was toooo far beyond him.
There's a stud that has no nut on it at all.. it's literally welded to the third.
Ideas to get it out?
1: chisel through it?
2: Sawz-all through the weld and the stud, then chisel the rest off?
3: File down the weld enough to get wrench flats onto it, and try to remove the stud with the blob attached?
It doesn't look like the weld really penetrated the cast third member housing at all.
Any ideas are welcome. Also there's a nut under the third that's rounded off and tight as hell.. vice grips just keep slipping. Can't get a box-end on it, can't get a nut splitter in there either...
- will do on the exposed welded stud.
