ponykilr
Guest
I am going to check out an F350 Saturday that has a bad rear axle. The guy says that the rear pinion is so loose you can move it up and down by hand. It is 2 hours away and I don't have access to a trailer that will haul it as the tires and wheels are very wide (Boggers)
If I take out the driveshaft and put it in 4high, can't I carefully drive it back?
I even thought about sliding the axles out and stuffing rags in the tube.
