M&M Offroad
- Mar 16, 2006
- mocksville
Started a build for Chris at Buckeye Performance. This will be getting a cj front clip and swing out doors.
That Chassis is sweet Chris. All I can say is WOW. PJ does some killer work. What LS engine is that? Is looks killer also.Thanks!
It should put out some good numbers. It has a 100mm tb on it for now but if that doesnt work out ill drop back to a 92mm.
BUCKEYE PERFORMANCE INC. 828-779-2242.
4.8 heheThat Chassis is sweet Chris. All I can say is WOW. PJ does some killer work. What LS engine is that? Is looks killer also.
Sweet. I just put one bad 4cyl. in mine, you better look out.4.8 hehe
Yea them 6.0 4 cyls pack a punch.
Ill keep you in mind if I need to use your 6.0 as a starter.
.. Hope to see progress over the break.You going to run truck manifolds? Or headers? Dont know what your plans are. Im sure it going to be headers, but if its truck manifolds an you need a set, I have a good set you can have.Yea them 6.0 4 cyls pack a punch.
