HELP!! Cherokee fuel problem?? P0171
cjgolfer7
SC
I have a 1997 Cherokee 4.0 aw4 231. It all started a couple weeks ago when I had to jump my jeep off. It took unusually longer for it to fire. I got in to and pumped the pedal to get it to catch and it fired right up and it's never been the same. Started idling rough and drinkingggg gas. I mean like 5 mpg. A couple days go by and I bought new plugs, wires, cab, rotor, fluids to do a routine tune up and it throws the check engine light on the way to advanced. Scanned it there and code P0171 bank 1 running lean. I'm no master mechanic but this thing was spitting out black crap and gas from the tail pipe. All I smell is fuel but no leaks. Changed all that stuff throw some sea foam in and still same crap. Changes the oxygen sensor close to the header, Upper I believe. No black junk but will still spit a lot of fuel out and running rough. Idk what else to do or the problem. I cleared the code and filled it up to head out of town tomorrow so we'll see how it does. But only a matter of miles before the code gets thrown again. When I return I plan on replacing the other oxygen sensor but after that is not sure. Any and all help and ideas and thoughts would be greatly greatly appreciated. Thanks in advanced.
Sent from my SPH-L720 using Tapatalk
Why did you change the oxygen sensor?
First things first watching the o2 sensors determine if they are fixed lean. If they are introduce a touch of propane into the brake booster hose while watching the o2 sensors, . If it switches rich you know the sensor is functioning and you truly have a problem indicating a lean condition. However as youve described it sounds like a rich condition. Map sensor, fuel pressure, a injector or a leaking fuel pressure regulator could all be the cause of a rich condition. Also could have an exhaust leak before the o2 You also should take a look at fuel trims an d see what their doing. If in fact it thinks its lean when its not it will obviously be extremely rich.
You could also have a pcm fault or a wiring fault but regardless of what it is you'll have to start with some live data. It is a speed density engine so vacuum leaks typically cause a high idle.
Sent from my SCH-I605 using Tapatalk 2
I had read somewhere that faulting oxygen sensors could lead to it and my upper was shot. I thought the same thing seems like it's a rich problem. The idle hasn't changed except for a little sputter. Like a slight skip. When the fuel comes out the tail pipe it comes in waves.. you start it up nothing for like 5 mins, then the next five mins I feel guilty for not collecting the fuel that's coming out and reusing it.
Lol understand that. Oxygen sensors can lead to it, but its a very simple test to determine if they are operating prior to replacement.
Theres a bunch of shop owners on here. Where are you located? I'm sure theres someone close who can help.
I'm in atl now, but come up to western nc and upstate sc a good bit. I drives fine for now just like to do a little better than 6 mpg hah.
I'm in blowing rock if your up this way give me a shout and I'll help out if I can. Theres a very good shop in savannah named intergrity auto repair if you get that direction at all.
Sounds good thanks for your help. Interesting enough I filled it up and put 250 miles on it and have in between a half and quarter tank. But still kinda runs a little rough at idle. But hasn't thrown a code or seem like it's drinking gas.
