I have a 1997 Cherokee 4.0 aw4 231. It all started a couple weeks ago when I had to jump my jeep off. It took unusually longer for it to fire. I got in to and pumped the pedal to get it to catch and it fired right up and it's never been the same. Started idling rough and drinkingggg gas. I mean like 5 mpg. A couple days go by and I bought new plugs, wires, cab, rotor, fluids to do a routine tune up and it throws the check engine light on the way to advanced. Scanned it there and code P0171 bank 1 running lean. I'm no master mechanic but this thing was spitting out black crap and gas from the tail pipe. All I smell is fuel but no leaks. Changed all that stuff throw some sea foam in and still same crap. Changes the oxygen sensor close to the header, Upper I believe. No black junk but will still spit a lot of fuel out and running rough. Idk what else to do or the problem. I cleared the code and filled it up to head out of town tomorrow so we'll see how it does. But only a matter of miles before the code gets thrown again. When I return I plan on replacing the other oxygen sensor but after that is not sure. Any and all help and ideas and thoughts would be greatly greatly appreciated. Thanks in advanced.
Sent from my SPH-L720 using Tapatalk
