I noticed the outlets, but thought the left one was phone. So I had to question the distance to the electrical recep. And I didn't know you were a shoe salesman
Baseboard didn't concern me too much; previous owner of my house, had Time Warner cable in 3 rooms. Full basement, so they drilled through the hardwood floors.
I have switched between Direct & Dish 3 times. Three different sat.s drilled into my [used to be new] roof. The last 2 installers, swear the previous did it wrong, by Not drilling/screwing into a joist. Well not 1 of them has hit the joist!
Last time I couldn't keep a signal, the "tech" guy showed up, said it was mounted to plywood, between the joist, & the section it mounted to,had pulled loose, from the rafter! F----- up my roof. I was demanding a chimney mount, that he swears the can no longer do=per Co. policy/safety. He Did come up with a under-eve mount, mounts to the facer board,at the joist. Wonder How long, they've had that? That sucker IS, a mount! As long as they hit the joist. Every install, I've had, the Companies, have had to send a Technician back, to Correct, what the "installer" did. Seems to me, they'd come out ahead, to only send qualified Techs.
