Sell the tires and buy some better axles and some reasonable sized tires.Need opinions on if they'll withstand that size tire. Will a 8" stock toyota axle hold up with 46" michelins?
With 20 inches of lift I hope you have addressed other issues first like pinion angles,and steering.And I hope your not running over a 3 inch body lift.Either getting the 46s or 44 boggers or tsl. My yota has over 20" lift that's why I'm needing to go so big on tire size
I have 5.71
PICSI really doubt he is gonna wheel it.
I bet its fine for what he will be doing.
Big ass trucks WILL get you laid..specially at da beach. Chicks dont care if its got Samurai axles.
Cant blame a guy for trying to get some stank on his hanglow.
And to add some tech:
http://zukaz.tripod.com/410suck.htm
And I caught hell with putting 60/14 under a xj running 44s on 8.5" lift.....
throw 6" of lift on it, cut the fenders and run 37-38s and have a good looking and reliable ride.....
yeah but he has a frame![]()
Had long duscussions on this... Most stock 4.10 used diffs have been work hardened over 100k + miles. Most trail only rig don't break them in correctly hence the softer gears that break easly.That link @72Rockcruiser has some solid tech but realworld ive seen more broken 5.29s than 4.10s and most guys i know run 4.10s
Because of the setup. A factory 4.10 setup is usually better than most people will spend the time to get. Just like dude says.
My gear guy (A Lexus Certified Master Tech) has not had one of his setups fail in over 30 diffs he has set up. ALmost all were 5.29s with a few 4.88s. He has been doing them since 1998ish. Most of which were for me and my buddies who drive like idiots.
Since we disagree on this I now hate your face and we can no longer be friends.
