RatLabGuy
- May 18, 2005
- Churchville, MD
'73 Bronco, original 302.
Ran (rough) last fall. Benn parked for 6+ months, no hood.
Can't get it started now, no combustion even pouring gas right into carb.
Best I can tell, does not seem to be a spark... if I pull a plug wire and hold it to the block, no spark arc (even if I put a jumper wire up into the plug cover)
If I put a meter on the output from the ignition coil that goes into the distributor, it reads 12v constant while the key is ON, while I try to start it (via bypassing the ignition switch and jumping the starter solenoid) it drops to ~10.5 or so.
So to me this means there is juice going into the distributor
Now, if I pull a plug wire off the distributor end and put the the meter on one of the "out" plugs of the distributor... nothing, ever, while starting. Shouldn't it spike while the rotor passes?
Does this mean there is something funky w/ the cap? The buttons didn't look too bad, I cleaned them really well, as well as the rotor leads...
I'm baffled as to what could have "gone bad" on a distributor while just sitting.
On a completely different note - when checking the wire routing, I realized that the plug firing order is set for a 351, instead of what it should be for a 302. After scratching my head awhile (since this DID work), I'm wondering if this means there is some kind of funky cam in in it... anybody heard of that? I'm having a hard time understanding how you could ever change the plug order so dramatically and it still works.
. However over in a different bundle that several of those were tied up with on their way to the dizzy, I found a different broken end wire... double fun: it's a 12v when in "run" but not just "start". So I don't know if thatst he one it had been hacked too (seems unlikely b/c the lengths aren't quite right) and it was just previously mis-wired or I have multiple random loose straggler wires (very possible).
