Flat Deck vs Dovetail. What advantage does the flat deck have?
REDLYNER
Mall Crawling Race Rig
Mountain Island
Is there a leverage advantage to a flat deck car hauler vs. a dovetail? I've read pages and pages of opinions, but why would one buy a flat deck instead of a dovetail when it comes to car hauling?
I've had both, but need a new longer trailer to accommodate a sxs and a jeep. The sxs needs ramps no matter if it's dovetail or not, so does that essentially negate the pluses of a dovetail?
Is there a weight/leverage advantage to a flat deck? The sxs and jeep need about 21' or so of deck, if I got a 22' trailer I was afraid of having the rear wheels of the jeep on the dovetail. Is that frowned upon in the loading/hauling world?
I could just get a 24' trailer and none of it would matter from a loading perspective, but I'm trying to keep it as light as possible (ie smaller trailer) to stay under my max gvwr and every 100lbs counts.
I know a dovetail takes leverage abuse. After about 6-7 years of hard use my dovetail fell off on the way to Charlotte when I-85 was so ruff. Had to winch it back up to get down there and back. Glad I was going for parts and not a car or something.
But after reinforcing mine I'd go with a dovetail again due to loading advantages with pulling up low riding / long vehicles.
I would probably go with the 24' dovetail. You may need the extra length to get the vehicles positioned for proper tongue weight. If the trailer is almost the exact length of the two vehicles, then you have no way to adjust your tongue weight.
I have a dovetail on my trailer, and never had a flat trailer so take my opinion as it is but the dovetail drags over everything when turning into or out of an incline. For that reason alone I will consider a flat trailer next time.
When I built my trailer I would not build dove tail due to it dragging.
However, I guess it your pulling empty & you get rear ended it would be like dukes of Hazard..
Makes it a little easier to load a low slung vehicle.
Just to reiterate, I'm pretty familiar with the major advantage of a dovetail from a loading perspective. But since I have to pull the ramps anyway for the sxs, that advantage seems to be negligible. But, that being said it is a convenience factor.
Really, I'm curious about hauling with tires on the dovetail. Does that create more leverage on the tongue?
And if it's got a SXS on the nose and a TJ hanging off the back, it's not going to have shit for tongue weight. Likewise, his 1/4 ton tow rig is having no part of a setup where the TJ goes on the trailer first.
Leverage on the tongue?
No. If anything (and this would depend on a lot of specifics) it would result in slightly less tongue "leverage" than a flat trailer of equal length.
That said the stress point will be the dove tail point.Long extended rides with a vehicle on the dove tail portion will stress that weld joint. The quality and style of that joint will determine whether that stress makes a shit bit of difference.
Many trips like this, 4k on dove and 4k on flat, never an issue.
.....but my tow rigs have always been 1 ton or larger duallys, currently f450 and 550's, previously chevy 3500 dually. Or with my 30' foot rv.
How long is that trailer?
For hauling a car... One would choose a dovetail because the car wouldn't bottom out on the trailer during loading. For 4x4, flat deck should be better as it won't drag as much and our rigs tend to have plenty of clearance where it won't bottom out when loading.
I bought a flat deck over the dovetail because I don't have a car to haul, just a buggy. And, I use my trailer for more than just hauling a buggy and the full flat deck was better for me.
Why not just out the sxs on the trailer sideways? What's the wheelbase versus the width of the trailer? I think a rzr is only like a couple inches over width, if that.
That was the original plan, but I bought a longer wheelbased sxs that had a 90"wb and is over 120" long. So it wouldn't fit sideways. I sold the sxs last week, so my plan is evolving.
