Need toyota pro's
Bhudgins
Asheville
Ok I have a 86 4runner that is throwing code 12 knock sensor so I checked the whole side of the block and there is no sensor and I can't find the plug but I did find a green plug that has the same shape not sure if it's the one I need so I thought I would turn to you guys and see if anyone knows what this plug is
The knock sensor probably has a blade style for that year, the green one I think is the oil sending unit.
Yea I know where it's suppose to go but it's not there on mine po I guess though it didn't need a knock sensor lol thanks for all the help think I found the wiring the plug is cut off and I am going to go get a used sensor since they are way over priced new I will report back on the outcome
Well I put a knock sensor in and no more check engine light and it has more power because the computer is not pulling timing thanks for all the help guys
Yea I got it 2 weeks ago the light was on when I got it been trying to find the damn wire they had cut the end off and zip tide it under the intake so I had to follow the wiring from the pin on the ecu to wear I found it
