RatLabGuy
- May 18, 2005
- Churchville, MD
Not a 4x4 question but it's a general problem applicable to most cars.
Pulling the 5spd manual trans in my '02 Mazda Protege5.
Got everything unbolted, except the pass-side mount, and bellhousing bolts.
Need ideas on how to support the engine as I remove trans, since it will be left w/ only the 1 mount on the P-side fender (at top of timing cover).
Working alone, in my garage - no lift, no hoist.
Apparently the engine will have to be able to droop downward to slip it out under the fender, so I can't just drop a jackstand under it.
I was thinking of dropping a 6' long 4x4" wood post across the engine bay (padded where it hits the fenders), and using that to strap the engine up to, using ratchet straps so I have some control.
Would that be string enough?
