madJeepJ10
- Aug 5, 2009
- Marion
there is a front axle i am looking at its a 8 lug j10 axle and on thr top of it it has a 6 on it dose that mean its a 60 or is it just a 44 with 8 lug hubs
Depends on how hard you hammer on it!
A Rubi 44 still has smallish unit bearings and smallish balljoints. Not to mention the knuckle and "C" size is still small. If you go to bashing it into rocks and holes, it wont hold up. If you wheel with some finesse, Rubi 44s with full alloys and knuckle gussets will probably be fine on 37s.
My advice would be...Sell the Rubi. (Probably could sell it for enuff to buy a waggy 44 and chromo axles!) Use the money to find, at least, a 44 that uses wheel bearings and spindles. These are stronger (remember a Rubi 44 is essentially a Dana 30 with a Dana 44 ring and pinion). Something such as a Waggy 44 with alloy axles, and good ball joints, you will be strong enuff for all but the roughest of wheeling on 37s!
... I'll put any jk d44 ring and pinion to any other d44 ring and pinion.
No one said anything about ring and pinion size. Ring and pinions are the same size! (I have built many 44s!)
Its the smaller knuckles and 'C's and the unit bearings that are weaker than an older waggy style 44.
You obviously have read all the articles on JK axles
) I never, once, brought up ring and pinion strength in my original post! Never said it was an issue! I don't care about the pinion size or any of that stuff in this thread. Properly set up ring and pinions on any 44 front generally aren't what breaks! It's the axles or the housings! (...and some cross pins!)Depends on how hard you hammer on it!
LOL!
Nice write up.You obviously have read all the articles on JK axles
BUT...
You're still focusing on the ring and pinions. (and what ever all that other fluff was about the rear axle flanges and lockers. This thread isnt about rear Dana 44s!) I never, once, brought up ring and pinion strength in my original post! Never said it was an issue! I don't care about the pinion size or any of that stuff in this thread. Properly set up ring and pinions on any 44 front generally aren't what breaks! It's the axles or the housings! (...and some cross pins!)
Once you go to alloy axles, they don't break as often. But still can be broken. And unless you invest in super joints, its generally not the axle that breaks anyway. It's the joint that breaks and then breaks the ears on the axles. No matter what model of Dana 44. And you can add RCVs and the ring and pinion will probably still be there after the unit bearing or knuckle breaks off! My experience is this... In respect to hammering on Dana 44s. I have seen many broken unit bearing knuckles, ball-joints, 'C's, and unit bearings! I cant remember the last time I saw a spindle or older style 44 knuckle broken. Even with the added leverage of high steer arms!
My point, if you had been paying attention, was that the axle assembly itself is weaker than the older spindle type dana 44 front ends. The 'C' and the knuckle is smaller. Unit bearing assemblies are weaker than wheel bearing type spindle assemblies. And, if you had read it. I mentioned the gusseting as helping the newer axles. Again, I said nothing about the ring and pinions!
Here is my post again, if you would like to read it this time before you start arguing a point that wasnt even brought up!
i dont know what to look for on google this is my google
