- Apr 16, 2005
- Sharon, SC
Ok geniuses educate the idiot (me)
We bought our house 5 years ago. The builder went belly up mid construction. We inherited a nice chunk of equity for being able to see past a lot of small stuff. The biggest thing at the time was there was never a yard "installed", the house was built on a hill and there were massive run off ruts. You could lose small children in these things. We spent a small fortune building a level yard. Hired a "pro", trucked in 20 dump truck loads of "top soil" and another 50 of fill dirt. Harley raked, planted, straw matted, fertilized you name it.
I went with a 20% rye 80% fescue blend to stabilize the dirt quickly. We had a very warm fall and the rye exploded. The ground was still so puffed up you couldnt walk on it much less mow and soon the rye topped out. Nearly choked all the fescue out. Year 1 we had a 70% lawn.
Year 2 I aerovated, over seeded and fertilized in the fall. Pre emergent in the spring and had about a 85% lawn
Year 3 did it all again and had about a 85% yard again.
I got frustrated spending a couple grand a year to make grass to cut and it wasnt "right" so Ive ignored it the last 2 years. And about 50% of my yard looks like a better homes and garden magazine cover, 40% is green, mostly weeds and 10% has bare/thin spots.
I've soil sampled and such and know what I need to do chem wise this fall. But I am also coming to realize without proper irrigation Im never going to get there. Looking around the irrigation material is cheap. I own a trencher. So with a little time Im thinking I can handle this fairly cheaply.
Here are some beginning questions I have I am hoping the board can help with.
- How many sprinkler heads can an average city water supply support at a given time? The net seems to have conflicting info.
- Since I will exceed this number I am guessing I will need a multi zone controller or a manifold device and manually control it. Any input here?
- My biggest concern and the reason I honestly havent done this before now. My house is on a private septic tank. The tank is in front of the house and uses a pump to pump the crap up hill to the drain field which is in the front yard. Pretty easy to tell where the drain lines are, they are bright green all summer. I am unsure how deep they are and very concerned about hitting them with the trencher. I will have to cross the entire drain field to get all the way to the road. Assuming I screw up here, and I will, how hard is it to repair a septic drain field line?
- How deep do these irrigation lines need to be. Im thinking not only about minimizing hitting lower stuff, but also about freeze protection.
Any other experience do's and dont's?
I'm an old pro at irrigation too but y'all carry on. Please don't hesitate to ask if you need anything.
