If you're on septic, you must make sure your system is sized for the (new) total of bedrooms, etc.
um, plus electrical...Oh yeah.... forgot about that part. Disregard what I said about no inspections.
You are changing the purpose of the room entirely from an outdoor space to an interior "living" heated space and thus would need to ensure all the typical standards are adhered to (fire blocking, fire caulk, insulation, electrical, life safety, proper wall construction, moisture control, etc) thus requiring an inspection.
To meet (current) code for living space, would the rafter/truss system over the space matter? Or the footers?
In a lot of older Ranchers, the carport doesn't always have the rafters or trussus on 16 or 24" centers. Even though it was continuous in the attic with the rest of the house, my old house in Lewisville (built '68) only had 1 or 2 across the whole span (making it like a 4' spread). I guess this was b/c there were no walls to support them on the sides or center. Side effect was that the ridge line over the carport had a slight sag to it.
And since there are no load bearing walls there often aren't footers poured into the concrete. I know that is a problem around here, I know a guy that got snagged on that when he wen to go get the permits to enclose his carport.
... his solution was to just do it anyway, and say, "I dunno, it was like that when I bought the house"...
thank u, I have some guys that have done work for us before. Just got to get them over here.Congratulations on your pending addition to the family!
Contact an architect or general contractor in your area who can quickly itemize what you would need to do to enclose the carport and turn it into habitable space and what permits and inspections you would also need. Get three quotes for the work.
Consider bunk beds as a budget alternative.![]()
If there are no closet then it's not a "bedroom" right? I'm ok with the inspections and stuff, member of my fd is county inspector. We are upgrading our electrical and hvac anyway. Thanks for all the info!You aren't adding load bearing walls, so foundation likely isn't a concern as the rafters/beams/etc above are already carrying the load through the existing walls, columns, etc. so long as you don't modify that, foundation and load on new walls should be a non issue.
I have yet to see anywhere in a legal code that requires a closet to be a bedroom. That seems to be a realty definition thing.Correct.
For resale, I'm putting a closet in our bonus room and it will count as a 4th bedroom. Otherwise, it's just a bonus room.
A surefire way to make sure it's not considered a bedroom is to have small, or no windows and no outside door.
I once took plans for finishing part of my basement to teh county for a permit. Guy looked at it, p[ointed to a room in the corrner labeled "media room", said, "Is this a closet? This looks an awful lot like a bedroom"
"No sir, for storing old games, a safe and media controllers. There's no windows, it's no ta bedroom..."
He insisted that the plans should just remove the closet so the health dept didn't get suspicious of what we were going to do with it (yes, here they have to send all the new habitable space permit apps to them for review).
He commented, "You know, this is a framed out closet, it would be pretty easy to add in later." hint, hint.
My 2 boys share a room now.
My thoughts exactly!Make the garage room a bedroom/game room for your boys. Put the baby in the current bedroom. Use wardrobes and dressers for the boys clothes that way you don't have to build closets
Being a firefighter I probably have more smoke and co2 detectors than anybody! Lol I'm alittle paranoid.From a technical standpoint, water intrusion is probably the biggest unknown. Carports are intended to get wet, and typically aren't designed to keep water out. Where water gets in, termites soon follow.
Aside from that, the room will have to have windows, and the house will have to be retrofitted with hardwired smoke detectors by law. One in each bedroom, one on each floor, one outside the sleeping area, blah blah etc. If you have any fuel gases in the house or have an attached garage, you'll have to get CO detectors.
