Van-go
Not an old man
- Dec 11, 2014
- Greensboro
I read through @Loganwayne 's learning curve XJ build thread and got jealous. I should have started one when I built my first jeep.
I really want a good place to document everything and keep track of some things. (past and present)
A lot of the thread will be pictures that I have taken along the way, but I will update as I do more.
For starters, My first jeep got me addicted while I was in college at ASU in Boone NC.
That is where I met @hurt4x4 who has taught me a bunch about this hobby.
We did a SOA and 8.8 swap on my first YJ with some other minor upgrades.
(Spartan Locker, SYE etc...)
Here are some pics of it.
I ended up driving too fast on the interstate (it was my DD) and the front drive shaft decided to come through the floor and wreak havoc on most of the running gear in one way or another.
I got pissed off cause all of my hard work and money was basically wasted...
So I did the only logical thing and went and bought another money pit.
Here is a picture of the day I towed it home.
Here is a link to the build thread of the guy I bought it from.
YJ Rebuild Project: My new DD - Pirate4x4.Com : 4x4 and Off-Road Forum
He had brought it it back from a bad place, but there was still a ton of work needed to get this thing right.
Here is what I was working with.
1995 Jeep Wrangler YJ - 165,000
Engine:
- 4.0 L inline 6 cylinder
- intake with cone filter
- Jeep TJ downpipe (routes around oil pan instead of under)
- Flowmaster muffler
Transmission:
- AX-15 5 speed
- External slave cylinder (replaced 500 miles ago)
Transfer Case:
- NP231
- Fully rebuilt 500 miles ago
- Full replacement Slip Yoke Eliminator kit
Front Axle:
- Full Width High Pinion Dana 44 from 1979 Ford F250
- Fully rebuilt 500 miles ago with all new seals, bearings, ball joints, etc.
- 5.13 gearing
- Yukon Spartan locker
- High steer knuckles and small bearing spindles from Chevy K10
- Brake calipers and brackets from Chevy K10
- Ford 5x5.5" hubs and rotors
- Warn manual locking hubs
- Stainless steel extended brake lines
Rear Axle:
- Full Width Ford 9" from 1978 F150
- 31 Spline big bearing housing
- 5.13 gears
- Open carrier
- Disc brake conversion using Chevy K10 calipers and Speedway Motors brackets
Front Suspension:
- OEM Jeep Wagoneer springs
- OEM shackles
Rear Suspension:
- Jeep Cherokee bastard spring pack
- spring hangers mounted to rear crossmember
- Currie greasable shackles
- Bilstien 5100 12" travel shocks mounted in shock hoops
Steering:
- DOM tubing
- Heim joints from Barnes 4WD
- Blue Torch Fab high steer arm on passenger side
Wheels/Tires:
- 37x12.50R16.5LT Goodyear Wrangler MT/R
- 16.5"x9.75" black steel wheels w/ 4.5" backspacing
- Internally balanced with 6 oz of Airsoft BB's
Interior:
- Grant steering wheel
- Tuffy 10" wide lockable center console
- Hurst shift knob
Other:
- Bestop Supertop
- RCI 2161A fuel cell mounted behind the rear seat in an Artec Industries cradle
- Fuel cell modified to accept a stock YJ fuel pump and sending unit
- Full belly skid plate from Barnes 4WD
- Winch plate on front crossmember
- LED tail lights
- Steel half doors with soft uppers
- Starter replaced 500 miles ago
Known Issues:
- No transfer case shifter installed
- Rear driveshaft is near full extension
- Steering box leaks
- Torn drivers seat
- Small rust hole in frame where it turns up in rear.
Also came with another 3rd member with 5.13 gears and a full spool. (needs all bearings replaced)
Engine:
Transmission:
- AX-15 5 speed
Transfer Case:
- NP231
Front Axle:
- 5.13 gearing
Rear Axle:
- 5.13 gears
- Open carrier
Front Suspension:
- OEM shackles
Rear Suspension:
Steering:
- DOM tubing
Wheels/Tires:
Interior:
- Hurst shift knob
Other:
- Bestop Supertop
- LED tail lights
Known Issues:
- Torn drivers seat
