BigSouth
Doesn't play well with others!
- Jun 8, 2011
- Shelby, NC
Delivered from East Coast Gear Supply. 4.56 Reverse Cut ring & pinion Nitro Gears and a Yukon 29 spline double drilled yoke.
I had aspirations of assembling all of this myself. However, none of these parts came with instructions and I don't own a bearing press or pullers. Any and all of my bearing work has been done with a brass drift. I can't spend this much on nice shiny parts to just to half ass the assembly. I'm hoping somebody on here can suggest a quality shop around here (Shelby, NC). I've found the famous "ZUK" and he's able to assemble it all for around $300, but it's gonna cost me $100 to ship it all to him and another $100 for him to ship it back. I welcome suggestions.
Google maps only places you about an hour from me. I'll definitely give you a call on my lunch break today. I'm all about supporting local businesses. I know this is gonna sound dirty, but is there any way I can watch the assembly? Teach a man to fish kinda thing.Give me a call and we'll work it out. I'll be glad to take of this for you
828-755-1005
All painted and welded straight to the frame. I want to go back and add some gusseting on all 4 sides. Maybe even some sort of skid plate to protect the u-joint. I'm planning on covering the entire bottom of the truck with either a steel belly pan or a piece of that poly stuff you see on the high dollar bouncers. Time and money will tell.
I'm glad you mentioned that because I am definitely unfamiliar. I'll take all the advice you wanna give. Thickness of said backing plate? Thickness of poly? Great place to buy them both?Incase you are unfamiliar, you still need a backing plate behind the plastic skids. AR plate is where its at.
No need for poly with ar plate, that shit is slippery as a buttery nipple. Build looks good.
Matt
Been there with driveshaft angle issues before, I used the offset ujoints from Oliver's, vibrated like hell but functioned and never broke.View attachment 241013
Then I got out and looked underneath. PROBLEM!! My front shaft is at its maximum angle sitting at ride height. I have to admit that the boys at Carolina Driveline warned me about this and I told them to build it anyway. I absolutely refuse to clock my case down. The app on my phone measures that thing at 38 degrees. Long story short, I wanted to do a hi pinion front diff anyway. Now I get to. After hauling the truck down to Carolina Driveline for some extra special measuring, they're pretty sure that a hi pinion diff combined with swapping to a pinion yoke on the case will afford me enough travel with my leaf springs. Worst case scenario, I'll have to limit the droop on the passenger side.
Matt
Just fyi, drilling it is a PITA.View attachment 242546
I took your advice and picked up this from a local welding buddy. AR400 1/4" thick. I've got enough here to make a flat belly pan that'll run from transmission pan to rear carrier bearing.
Order weld washers, and blow the holes out with a plasma, weld in washers...easy peasyJust fyi, drilling it is a PITA.
