Oliver's
Drive Line & Gear
- Jul 16, 2005
Do your angles match? .
Agreed, first thing I'd check.
Do your angles match? The extra mount on the 205 just helps with the gravity load of the t-case, and helps control rotation of the case due to torque loading. Neither one will have an effect on the rear driveline angles.
Yea I need it I think. I've been lucky to wheel it like it was built and not messed up the rear of the AW4 I think. I guess the side mount I put on from the start helped there.Do your angles match? The extra mount on the 205 just helps with the gravity load of the t-case, and helps control rotation of the case due to torque loading. Neither one will have an effect on the rear driveline angles.
The angle of the output on the transfer case and the angle of the pinion yoke on the rear axle?
Yes.You went from a CV style driveshaft to a non-CV style driveshaft. The two are designed to operate at different pinion angles. See below. Ignore the numerical values of the angles as yours will vary but note how they relate to one another.
That is what I thought they were referring to. I know mine is set up like the CV shaft.
Yea bout that.... remember when we were discussing track bars? Ugh.....You'll need to rotate your pinion down then. You can do so by shims (machined not cast please) or by welding on new perches.
Yep and I forgot that whole driveshaft angles thing.......Damn, I forgot all about that...
Now I have to deiced what to do about the fact that I have my pinion turned up for a DC shaft
Ok spent last week in Harlan from the 4th - 9th with NAXJA @ the Crawl. Thanks for building a beefy driveshaft. Now I have to deiced what to do about the fact that I have my pinion turned up for a DC shaft.... Thanks @Oliver's
Right now that is my attitude. It gets a little shaky when I let off after moving a little faster than I should with this thing but it's all holding together so far.If it is solely a trail rig and sees no road time, I wouldn't sweat it too much. By having the pinion up a little bit, it'll help keep the yoke out of the rocks. Obviously, we're not talking about a pinion that is turned up and absurd amount or anything.
Would love to but right now I have another rig to build so this one can get a complete redo.Sounds like a 4 link would work.......
