Lurch830
messin' with sasquatch
- Mar 1, 2007
- Wilton, NC
Tow pig in my signature has lately been slower & slower to crank/fire and now will not crank at all (still spins). I need some things to check before I take it to a shop to be fixed.
I thought it was a battery issue, but I'm relocating my batteries to the toolbox since the 'new' ones I get from work are too big for the battery trays (CAT generator batteries), it will get some weight off the front end & they're free. They are charged & test good with a load tester and will spin the starter for a few minutes (~30 seconds at a time) before slowing down. So I'm thinking it could be any of the following:
computer issue?
bad glow plugs (probably not since it doesn't crank when the block heater is plugged in?)
bad fuel pump
clogged tank fuel filter/pump (fuel filter under the hood was changed 6k ago)
Any other ideas or things I should check? I won't be able to get back to it until the weekend and I'd like to knock out as many as I can at once.
Thanks,
Brandon
computer issue?
bad fuel pump
Thanks,
Brandon
