I’m just trying to figure why you guys have so many extra drinks. I’m always thirsty and if a drink last long enough to freeze we got other problems.
To try and make my earlier comment clearer, between two otherwise isolated open systems an adiabatic wall is by definition impossible. This problem is solved by recourse to the principle of conservation of energy. This principle allows a composite isolated system to be derived from two other component non-interacting isolated systems, in such a way that the total energy of the composite isolated system is equal to the sum of the total energies of the two component isolated systems. Two previously isolated systems can be subjected to the thermodynamic operation of placement between them of a wall permeable to matter and energy, followed by a time for establishment of a new thermodynamic state of internal equilibrium in the new single unpartitioned system. The internal energies of the initial two systems and of the final new system, considered respectively as closed systems as above, can be measured. Then the law of conservation of energy requires that: Δ U s + Δ U o = 0 , {\displaystyle \Delta U_{s}+\Delta U_{o}=0\,,} where ΔUs and ΔUo denote the changes in internal energy of the system and of its surroundings respectively. This is a statement of the first law of thermodynamics for a transfer between two otherwise isolated open systems. For the thermodynamic operation of adding two systems with internal energies U1 and U2, to produce a new system with internal energy U, one may write U = U1 + U2; the reference states for U, U1 and U2 should be specified accordingly, maintaining also that the internal energy of a system be proportional to its mass, so that the internal energies are extensive variables. There is a sense in which this kind of additivity expresses a fundamental postulate that goes beyond the simplest ideas of classical closed system thermodynamics; the extensivity of some variables is not obvious, and needs explicit expression Also of course: Δ N s + Δ N o = 0 , {\displaystyle \Delta N_{s}+\Delta N_{o}=0\,,} where ΔNs and ΔNo denote the changes in mole number of a component substance of the system and of its surroundings respectively.
If the ice isn't completely frozen, it will hold the cooler temperature at the freezing point until completely frozen, then the temp will decrease eventually down to the 12deg outside temp. The water actually releases heat during the phase change from liquid to solid, which is why the temp stays at 32 deg until totally frozen. Beer doesn't freeze at 32deg, because of the alcohol. So yeah, ice makes a good thermal buffer for the beer, especially when the beer is already above freezing and has some heat to release in the cooler.
You're way smarter than all those people who think you're insane for using ice in a cooler with beer. If I saw you do that, I would laugh because you're obviously a badass, and then I'd buy you some beer for the cooler. Because, you know, scientific research.
You must have cut and pasted that from somewhere; the "\displaystyle" gives it away.![]()
That, or....
Sodium bicarbonate and calcium chloride?
This brings us to the newest hippie trend...."raw" water.
Unfiltered Fervor: The Rush to Get Off the Water Grid
Sure that's not @RatLabGuy in the video??
Sorry that's as far as I got.I knew by then it would be above my pay grade.This is an easy one, it is based on the pressure within the atmosphere of Earth (or that of another planet). In most circumstances atmospheric pressure is
