1-tonmudder
Doin my part to stir the pot.
- Apr 17, 2005
- Greeneville TN
Anybody have a ball park ideal of what is cost to have a 02 Common rail 24v 5.9 pump rebuilt?? Fuel at the pump but none getting to the injectors.
These pumps are shelved in nearly every diesel shop on the country. It's cheaper, faster and more reliable to just buy a replacement. Seems like thoroughbred diesel has the cheapest prices. I sell mine for around $1200 iirc (We've loaded up the whole shop and headed to Kansas city
- attending the vision high tech training ) .
Before replacing it verify supply pressure is a minimum of 10psi - ideally 14. Once the new pump is installed make sure that at wide open throttle it never drops below 10psi. There is a test possible where you standalone the pump to eliminate truck side issues such as ecm or powers and grounds.
Says 02 common railHe doesn't have a CP3, it's a VP44 truck.
Beware, advance sells a cardone rebuilt pump. Had a customer buy 4 at $1800 to get one that would run. Much better options available!Is it common rail with cp3 or is it a vp44? If it's got 6 injector lines coming off the back, it's vp44 and probably is no good. I got one for one truck thru advance, they had them at the warehouse.. forgot how much it was, but it's going strong still two years later. Check fuel pressure! I'd install a gauge and a good lift pump if you're keeping it for you. Usually the lift pump dies and the vp44 continue to run the truck but dies slow death from lack of cooling fuel.. it'll continue to run and restart because it has enough suction to pull fuel from the tank once primed. Rotor seized in the one I did.
Would likely still be a vp44.02 Freightliner/Thomas school bus
That's a vp, not Common rail.![]()
They wern't terribly reliable. I'd vote you've got lower than acceptable supply pressures which will kill it quick. The problem is the pump will run with virtually no pressure what so ever as long as there's just a touch of volume. Any trouble codes?So is that why it’s bad w just 114k on it??
Why'd he buy four units? Warranty at Advance would cover if they are defective...Beware, advance sells a cardone rebuilt pump. Had a customer buy 4 at $1800 to get one that would run. Much better options available!
