RatLabGuy
- May 18, 2005
- Churchville, MD
What is a good tool for cutting out copper pipe in tight space?
I need to remove this copper pipe to replace it (leaking). I need to save tbe vent line, the upper vertical section.
E.g I need to make a horizontal cut just above the Wye and another, vertical on tbe right.
Problem is not much room to saw. Can't use a sawzall bc tbe blade has too much tbrow and hits wall behind. Typical 4" cutoff wheel is nowhere near deep enough cutting surface to slip in. No room for hacksaw. I can push the apex aside if needed.
I need something like a seawall where the blade only moves 1/2" back and forth....?
Or a Dremmel multimax with a huge clise-cut blade...
