- Mar 20, 2005
- Morganton NC
OK so enough is enough. I couldn't hold back any longer! I gotta keep up with the Jone's, Or should I say, The Minton's, the Ellis's, The Maloney's, The Poplin's, the Wilson's and the Thomas's
and so on!
My Jeep UPNOVER II, will be going under the knife soon. Just after our July 4th ride. Chris Ellis @BUCKEYE PERFORMANCE INC. will be doing the build. The plan?
Full width trusses, on both axles, Double ended ram, Fox Coil overs on all 4 corners, Dually 14 bolt in the rear(swapping out my guts into this one), Aluminum Lower links, Heavy wall steel upper links, Not sure yet if it will be 4 or 3 linked in front, depends on clearances. Goal is to get it lower, stretch wheel base so tires are the first on the rocks, and last to go over a ledge.
I have already upgraded to Reid Knuckles, 43 stickies, Hydro steering and so on.
There will be some parts for sale afterward, stay tuned for those!
and so on!
