My front is running off the regular winch, but I bought a Warn 1700 on sale from Northern a while back (and got the no-questions-asked warranty). It's running through a little pulley to act as a snatch block. It can suck the suspension down pretty well into the bump stops, which takes ~3800lbs to fully compress them with the current settings on the coilovers.so do most of you just hook your normal winch up to it, and just unhook when you need it.... or do you use a seperate one? if you use one just for that, how big of a winch do you really need?
i've got my front hooked up to the axle, and a small warn 1500 in the rear. I've not actually used the rear on the trail yet, but i use the front all the time. Its amazing the difference it makes in climbing stuff.
I used the front winch right here to put more weight on the front and transfered the weight to the front wheels, walked right up.
that sound about right? lil diff for multi-rate springs but same gist...
I just pulled my numbers from the coilover calc..For the ones running these on the front without a roller set-up - have you ever had to use the winch in a climb situation and had to un-hook it from the axle, to be able to run cable? That seems like it would suck. Would it be possible to use nitro charged shocks and just play with the rebounding to have the same effect?
