jeepin1995
undecided......
- Oct 21, 2006
- Cary (raleigh) nc
My rear has been humming some the last 2 weeks and this morning it got bad. Limped back home and pulled the diff cover. Found the drivers side carrier bearing is shot. passenger side looks good. my question is if i replace just the drivers side bearing and race, and re-install the carrier shims as they came out, do you think I would be ok with no further adjustments needed?
ALSO, there is minor damage on the gear teeth. like on the top edge, where the carrier moved from the pinion and it wasn't hitting the whole tooth (SEE PIC) would this be ok to run for a few thousand miles?
