Was hoping you’d chime inNot unless you intend to do an engine swap at some point.
I'll be the one to disagree here, I have two JKU's an 08 'x' with the 3.8 and a '15 Sahara with the 3.6, Both Automatics, both with 3.73's and both on 35s. The 3.6 is a much nicer motor, BUT if the two jeeps are otherwise nearly identical and similar mileage, I sure wouldn't pay $3000 more for the 3.6, It's not THAT much better. Maybe $1500 better, but $3000 is a pretty big premium.
Couldn't disagree more lol
3.6 has about 55HP more if I remember right.
I would buy a 3.8 if the deal was good, as in the Jeep was well built with ALL the stuff you already wanted, and it was nice. But I would intend on putting an LS in down the road when it needed a motor. I’d just live with the oil consumption, lack of power and mpg in the meantime.
On the flip side if the Jeeps were nearly the same, and it was $3k difference to get into a 3.6, I’d certainly spend more up front because at some point you’d need to replace the 3.8 anyway and I’m sure that would cost roughly $3k
I would bet that moderate wheeling in low range with a 3.8 wouldn’t leave you lacking much if geared correctly, you’d really only feel it going down the highway. And since you are a mall crawling poser, that’s you most of the time...
*22RE has entered the chat
Who needs horsepower to idle down a trail all day. Are we all rock bouncers now![]()
True. But JKs weigh a lot, so they do need some torque/HP.
And if you ain’t having to back up and bump it, are you even wheeling?
Why are yall worrying about HP? I wanna see side by side torque curves.
