98 TJ won’t run
Collin Crosby
Horneytown, NC
Hey y’all hope everyone is doing good with everything closing down.
I got a problem and don’t know where to start I got a 98 TJ 4.0 that was dead last week so I figured I left something on and charged the battery. Battery held a charge and I drove it to work when I was ready to leave work it was dead again so I jumped it off and I figured the alternator was bad drove home and changed the alternator now it won’t run it will start good but no fire.
I’ve replaced:
Alternator
Crank sensor
Battery
Spark plugs
Ive check:
Fuses and relays
Grounds
All I got is a test light and the ignition coil is not getting any power when the key is on and while starting
I don’t what to do anymore everything looks fine I’m wondering if messed up the Ecu or something jumping it off or disconnecting the battery while it’s running any suggestions will be appreciated thank you.
When you turn the key do the lights, radio, and everything else work it just won’t crank?
I had that issue a while back on mine and behind the key cylinder is a square plastic rod that goes into the ignition switch, mine had broke/wallered the slot out and was slipping when I was trying to turn it over to start, when you pull it the key cylinder and stuff out, you’ll see a little square switch, stick a screwdriver or something in it and cycle it through the positions and see if it’ll start.
Yeah I looked it and it was moving when I turn the ignition but I don’t know if worked good enough it’s orange right
That red circled piece is what’s usually broke. It goes into a square hole/switch that as the key turns it makes stuff turn on, engine start etc.
Okay and yours mm
Any update man?
not yet do I gotta pull the steering wheel or take those special torx bits bolts out to get it off
Okay and yours mm
It’s been a bit but steering wheel stays on, Pry the key insert cover off and a couple of screws top and bottom on the cover and pull the cover off the steering column. There’s 3 maybe torx bolts holding the cylinder in. Take those out and everything should slide out. I’ll go do it and take some pics if you want. I can do it in probably 10 mins. Its not too bad, just pull stuff apart, there’s not much to put back together.
Not sure what the “Okay and yours mm” is about but hell yeah either way lol
You don’t have to I gotta get those special torx bits with the hole in the middle to get it off everything closing early and wasn’t able to get them today and I was about to reply to your other post and notice you sent another one
gotcha. It’s not too bad man. That’s probably the problem. The connection piece can be hard to find. I junk yarded mine and in the mean time I used a screw driver to start my Jeep lol eBay probably has them if that’s what it is.
Took it apart everything looks fine
Did you stick a screwdriver or something in there and turn the switch over to see if that made it crank?
you might’ve lost a wire/ground or something. What’s got you so hell bent on a new ecm out of curiosity? That could be it, but I’d hate to see you get a new one and it be something else.
No it starts but I can’t get any power to the distributor, ignition coil and cam sensor
I thought about putting a screw driver in there and turning it but I didn’t want to mess anything up in there
Switch is top left, that’s a wiring diagram. Idk if it’ll help you or not but it might give you an idea.
Do you have fuel pressure? There’s a schrader valve on the fuel rail, if you push it in fuel should squirt out.
You can also try a little starter fluid, if it fires that will tell your that you have spark but no fuel.
Tried starter fluid want do anything
When you first turn the key on the ASD (automatic shutdown) relay should close & send 12v power to the coil & injectors. After 2-3 seconds the ASD should open & kill power to the coil & injectors. When you turn the key to start & the engine starts cranking you should get the ASD closing & 12v power back to the coil & injectors if the PCM gets a signal from the crank position sensor.
No signal, ASD stays open.
Also when the PCM sees a crank signal it should start pulsing a ground signal to the coil & injectors & it should start.
Check for each of these conditions & that’ll give you some kind of idea on what’s up.
